It is currently Sun Sep 14, 2025 2:08 am
PostPosted: Tue Nov 14, 2023 4:08 pm
I learned from Andy Birko that his web store,birkonium.com is now offering the LMI binding cutter bit and complete bearing sets. Birkonium is now the authorized supplier of the original cutter and spacer bearings. This came as good news to me as I depend on the availability of the cutter tool and replacement bearings to maintain my binding and purfling cutter. Here is a link to the cutter and bearings:
https://birkonium.com/shop/tools-misc/binding-cutter-bearing-set/
Birkonium is an OLF sponsor and my source for CNC necks, bridges and fingerboards.
MJ Franks
These users thanked the author Mike Franks for the post (total 7): ThomLuth (Thu Nov 30, 2023 10:15 pm) • LanceK (Fri Nov 24, 2023 10:30 am) • Kbore (Thu Nov 16, 2023 4:55 pm) • Pmaj7 (Wed Nov 15, 2023 12:24 pm) • joe white (Wed Nov 15, 2023 7:35 am) • Colin North (Wed Nov 15, 2023 3:56 am) • Hesh (Tue Nov 14, 2023 5:47 pm)
PostPosted: Wed Nov 29, 2023 4:54 pm
Hey guys - this post is true and even better news - I should have the cutters and bearings in next week in time for a great Christmas present.
Question for y'all though - These bearings are sized such that you can cut a ledge from .060" all the way to .230". I'm trying to come up with some packaging for the bearing set and as far as a description goes, do you think it's better to label the bearings which size they're cutting or the diameter of the bearing?
I'm leaning toward putting the ledge size in there but, since this is a 1" cutter, the math is really easy to if you have the bearing size.
So which would you rather have in the storage box - bearing diameter or ledge width and why?
Thanks!
These users thanked the author Andy Birko for the post: Hesh (Thu Nov 30, 2023 12:05 am)
PostPosted: Wed Nov 29, 2023 5:25 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
The almost equivalent bearing/cutter system that StewMac sells comes with a chart that gives both numbers for each bearing. I use both numbers when working out the dimensions for binding/purfling channels and when using the bearings. So I like having both numbers readily available.
These users thanked the author J De Rocher for the post: Pmaj7 (Fri Dec 01, 2023 2:55 am)
PostPosted: Thu Nov 30, 2023 8:59 pm
Ledge size.
PostPosted: Thu Nov 30, 2023 10:52 pm
City: U.P.
I got tired of fumbling with bearings and calipers and math, StuMac, but same principle. Here's my solution. Thanks Andy for picking up LMII bearings.
I use plastic tubing to protect edges on some other cutting bits I keep in the box.
Brian
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Colin North (Fri Dec 01, 2023 5:41 am)
PostPosted: Fri Dec 01, 2023 12:19 am
Ledge size for me and terrific news!
PostPosted: Fri Dec 01, 2023 5:42 am
Brian
Nice one, got to do something similar!
PostPosted: Fri Dec 01, 2023 12:55 pm
Ledge size is great info, but I also like to verify that I am about to use the correct bearing, so having the bearing diameter along with the ledge cut depth is appreciated.
These users thanked the author Mike Franks for the post: Pmaj7 (Fri Dec 01, 2023 6:03 pm)
PostPosted: Fri Dec 01, 2023 2:08 pm
First name: R.M.
Last Name: Mottola
Good news Andy. It is a great set!
My intentions were to make a nice case like Buddy's for my LMI bearing set but I never got around to it. I do have this CAD drawn card which I keep with the bearings.
R.M. Mottola
LiutaioMottola.com
Author of the books Building the Steel String Acoustic Guitar, Practical Design of the Acoustic Guitar and Similar Instruments, and Mottola's Cyclopedic Dictionary of Lutherie Terms.
I don't check in here very often. If you need to contact me the best bet is via email through the contact page on my site.
PostPosted: Fri Dec 01, 2023 6:07 pm
Both. Ledge size is great for storage and use, but I always check diameter with my calipers.
Sent from my SM-N960U1 using Tapatalk
PostPosted: Fri Dec 01, 2023 9:40 pm
ledge size gives quick and easy bearing changes for a specific cutter for the desired result
bearing size gives reference if one uses a different diameter cutter for whatever reason
skip the choosing and do both to cover all bases
PostPosted: Sun Dec 03, 2023 10:35 am
City: Lawrence
Zip/Postal Code: 66047
I would prefer bearing size, I use the bearings in other wood working projects with different diameter cutters.
PostPosted: Sun Dec 03, 2023 9:56 pm
Here’s my set up…
PostPosted: Mon Dec 04, 2023 7:24 am
Brad, your setup looks just like mine. I’ll add a photo after I get down to the shop (if I can remember-ha).
PostPosted: Wed Dec 06, 2023 9:31 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I like to have both so I can measure a bearing and put it back in it's correct location on my board.
Tony Thatcher
Bozeman, Montana
PostPosted: Thu Dec 07, 2023 12:02 am
Users browsing this forum: No registered users and 58 guests
